3D model as stock
britovsekmatic128
3D model as stock
britovsekmatic128
how would i go on and use an 3D model as stock then make further changes to the stock model to "tell" F360 what is to be machined? I hope that makes sense.
seth.madore
Okay, so your "Stock" does not have that R17.5mm radius groove thru it, correct?
A couple pointers:
1) Both files can exist in the same Fusion file, either one as a native and the other as an inserted component, or just to native components in a file.
2) Create a Setup.
3) Select the model that represents which part will be the final resulting model as your "Model":
4) Select the model that represents your "Stock", under your Stock Definition
Seth Madore
britovsekmatic128
Thanks for the fast reply @seth.madore
I'm having trouble to get the results you posted, not sure if im importing the component correctly should i align them in design or is it something else.
seth.madore
Give this a watch:
Seth Madore
britovsekmatic128
Thanks a lot @seth.madore !!
BTW nice shop! Just watched the video you did with Saunders.
seth.madore
Thanks! I recently put on that addition I mentioned in the video, now rocking an additional 1,400 sq/ft!
Seth Madore
britovsekmatic128
Nice!:flexed_biceps:  Gotta make a new shop tour then!:winking_face:
