Fusion Manufacture
3D Deburr help, trying to chamfer both sides of a bore
4 REPLIES 4
NickErmis
153 Views, 4 Replies
Hello, I am trying to use the new 3d deburr strategy and cant figure out how to get the bottom side of a bore.  I am trying to use a double sided chamfer tool.  I am hoping I am missing a simple setting, but if so not sure which one it is.  Any help would be appreciated.   I was able to do it manually with constructed geometry using the 2d contour strategy, however I would prefer the tool not retract.  File is attached.
Thanks in advance
4 REPLIES 4
seth.madore
in reply to: NickErmis
Sorry, you cannot use the Deburr toolpath in 3-axis mode to deburr the back end of holes with a tool such as that. You can, however, use a Lollipop tool:
Seth Madore
NickErmis
in reply to: seth.madore
Hi Seth, Thanks for the quick response and feedback.  I did attempt with a lollipop cutter and couldn't get that to work properly either.  Fusion file attached.  Not sure what I am missing.
seth.madore
Hmm, there's something going on with the success and tool size. I was able to drop down to a .187 lollipop and get a toolpath:
I'm thinking it's due to the limited amount of lead-in/out control that we have...
Seth Madore
NickErmis
I will give it a shot.  Thank you
