3D Deburr Control over Toolpath
weber_dominic
weber_dominic
I would like to use 3D Deburr for a 5 Axis Toolpath. Can i get some more control somehow over the Toolpath? The Simulation keeps going to it's axes Limits and has to retract and reconfigure then when it reaches B-30. While it actually could have a way easier toolpath without all those motions.
I thought this would be actually a very easy toolpath but for some reason i can't get it to work properly. How would you mill this chamfer?
rengfx
I've had good success using a ball endmill, and either leaving it in 3 axis mode with Tool Orientation, or full 5 axis where I select the edges like you have and use set Axis Limits either to the Tool Orientation or the Setup Z axis
I actually haven't used even a chamfer mill with it, I notice on your toolpath its locked to a fixed point on the tool because its a chamfer mill, you have more flexibility with a ball endmill or lollipop mill
