Fusion Manufacture
3D Adaptives taking Forever in the software as well in real life.
2 REPLIES 2
kmaddenVFQJ3
209 Views, 2 Replies
For the past few weeks generating 3d adaptive tool paths that have to deal with slopes or undercuts take forever to generate, and when they finally do the tool path itself usually takes about 4 times longer than it should.  I keep getting a huge amount of redundant tool paths added in that aren't really following my step over or step-down settings.  Is there some new setting that changed recently that I am missing?
Attached is an export of what it's doing.
2 REPLIES 2
seth.madore
in reply to: kmaddenVFQJ3
For starters, your Min Stepdown under "Flat Area Detection" is set to an insanely small value. Try bumping that up a fair bit, .01" as an example.
Seth Madore
kmaddenVFQJ3
in reply to: seth.madore
That was it, thanks.
