Fusion Manufacture
3D Adaptive w/ Rest Machining enabled air cutting what was previously milled
3 REPLIES 3
FrodoLoggins
80 Views, 3 Replies
Everything in red:
Was milled away from this previous operation:
3D Adaptive settings:
Screenshot 2024-02-21 at 1.00.51 PM.pngScreenshot 2024-02-21 at 1.01.04 PM.pngScreenshot 2024-02-21 at 1.01.09 PM.png
Clicking "Reduce air cutting" removes most of the air cuts on the left side but leaves a bunch on the right:
Toolpath tolerance + smoothing = almost twice my stock to leave.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
Simply change your Top Height to the top line of those inside corner rads
Please click "Accept Solution" if what I wrote solved your issue!
I would do that but then I'd usually get false positive collisions. Not looking to micro manage if a collision is actually a collision or not.
seth.madore
in reply to: FrodoLoggins
Tighten up your tolerance to .0001":
Yep, calculation time is going to be a pig.
This is just the first iteration of "reduce air cuts". We have lots more improvement to go on it, so WYSIWYG for now
Seth Madore
