Fusion Manufacture
3D Adaptive: Tool not ramping deep enough?
8 REPLIES 8
Message 1 of 9
FrodoLoggins
314 Views, 8 Replies
I'm looking for my 3D Adaptive op to also helically ramp down into the two counterbores. The tool is a Ø.25" and the CBore is Ø.315". With .005" of stock to leave a ramp diameter of ~.052" should allow the tool to ramp down all the way. However, even with a ramp diameter of .001", and a minimum stepdown of just .001", this is the best it can do; only ramping down a little:
Screenshot 2023-04-28 at 11.29.25 AM.pngScreenshot 2023-04-28 at 11.29.47 AM.pngScreenshot 2023-04-28 at 11.29.59 AM.pngScreenshot 2023-04-28 at 11.30.24 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
8 REPLIES 8
Message 2 of 9
engineguy
in reply to: FrodoLoggins
@FrodoLoggins
Just needs some "tweaking", works here, see attached file for settings and images below 🙂
Message 3 of 9
FrodoLoggins
in reply to: engineguy
Thanks. It looks like the workaround is to make my stock to leave any value less than my tolerance + smoothing. Weird because .005" stock to leave leaves plenty of room for the end mill to ramp down.
Message 4 of 9
drd_808
It doesn't have anything to do with smoothing or tolerance or stock to leave
Your minimum cutting radius is just too big. Make it 0.005 (instead of 0.025 on the 4th tab 3rd box from top) and it will work
Also change helical ramp diameter back to .2375 (or whatever your default is) how you have it setup it will force it to use your "minimum cutting radius" value to set all ramp diameters (2x minimum cutting radius) instead of defining a range and allowing fusion to use what is optimal
"Helical ramp diameter" should actually be called "helical ramp diameter max" which pairs with the option below and allows you to set the range of allowable ramp diameters
Message 5 of 9
drd_808
Just for fun I made a part with 5 holes in it that have hole sizes of .315 up to .335 in .005 increments from right to left. Ill post a pic of the part along with the options in 3d adaptive's 4th tab with different min cutting radius values
(.005)
(.025)
(.028)
(.030)
Message 6 of 9
FrodoLoggins
in reply to: drd_808
Thanks so then I'm confused. In the below video I'll show a working toolpath with .01" leads and a helical ramp diameter of .058". If I bring the leads down to just .001" and only increase the helical ramp diameter by .001" to .059" the toolpath doesn't ramp into the counterbores:
Same thing with stock to leave; If I take that same working toolpath and reduce the lead ins from .01" to .001" but increase the stock to leave from .002" to .003" it also doesn't ramp down:
Message 7 of 9
FrodoLoggins
Wait hold on....
Message 8 of 9
drd_808
minimum cutting radius is the option that was causing your problem not leads. 4th tab, 5th option from the top (3rd box from the top) reread my first response. I edited it yesterday after I had posted originally.
Leads dont matter in this case. It'll override those in 3d adaptive (some strategies it wont so keep it in mind for furture issues with ramping or empty toolpath)
Message 9 of 9
drd_808
the reason stock to leave makes the toolpath work is because you only need .001 radially more space to make the strategy able to generate the ramp. You can also incrementally decrease the minimum cutting radius to show the same effect but if you put min cutting radius to 0.005 you can make stock to leave 0.015 and it'll still work
