Fusion Manufacture
3D Adaptive: Not milling as much as it did the last time I ran this program
2 REPLIES 2
FrodoLoggins
72 Views, 2 Replies
I have a minimum stepdown of .01":
I have made 0 changes to the toolpath. All I know is the last time I ran this program the subsequent facing operation took off wayyyy less than this much material:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
2 REPLIES 2
Thats because your top height is set to Model, not Stock.
Consider that you could replace all those separate surfacing ops with one single Scallop, unless the customer says they need certain cut directions.
Your spot depth is also into the part.
Please click "Accept Solution" if what I wrote solved your issue!
Which spotting operation, this one?:
Seems fine on my end.
