Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
3D Adaptive Invalid Tolerance Bug
6 REPLIES 6
Taylor-R
347 Views, 6 Replies
I'm getting the following error when generating a 3D adaptive toolpath: "Error: Invalid tolerance. (tolerance > 0)"
The error goes away when I set the tolerance to >= .003 inches, anything less than that throws the error. Has anyone else seen this?
The file/model is proprietary so I cannot share. Passes tab settings and error message screenshots attached, let me know if you need more info. Running Fusion version 2.0.16976 on Windows 11
Thanks!
6 REPLIES 6
seth.madore
in reply to: Taylor-R
This is a known bug that is logged as CAM-47310. I'm not aware of a workaround, other than to set the tolerance to a value such as .003"
Seth Madore
Taylor-R
in reply to: seth.madore
Thanks @seth.madore . For future reference, is there any way we can search for known bugs? (So I won't clutter the forums with questions that are already raised)
seth.madore
There is a search function for the forum at the top of the page:
Inputting "3D adaptive tolerance" will get these two recent hits (one is your post, the other points to the one that I was thinking of)
Seth Madore
seth.madore
It's also a fair assessment that the search function is far from perfect and not always going to be so forthcoming in its results.
Seth Madore
HughesTooling
Is this only a problem working in inches? I use 0.01mm all the time and never seen this error.
Mark
Mark Hughes
Owner, Hughes Tooling
seth.madore
in reply to: HughesTooling
Yes, I think so
Seth Madore
