Fusion Manufacture
3D Adaptive ignoring stock to leave
1 REPLY 1
FrodoLoggins
107 Views, 1 Reply
Generated fine yesterday. Didn't change anything. I have 11" of stock to leave so it should have only milled a pocket about 1.5" in diameter like it did yesterday with the same settings.
Screenshot 2023-10-04 at 12.48.57 PM.pngScreenshot 2023-10-04 at 12.53.18 PM.pngScreenshot 2023-10-04 at 12.53.57 PM.png
Restarting Fusion doesn't help.
EDIT: Same stuff going on with some of the spiral toolpaths. No matter how small of an outer limit radius I specify or how much stock to leave or any combination it just mills whatever. Sometimes milling outside the machining boundary.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
No need to have your model selected, stock selected, and boundary selected. Youre over defining a 3D toolpath with info. Only select model if you are ADDING features to be milled (like surface patches)
Only use boundary when trying to avoid cutting into something or to confine a cut direction
Only use stock when it's necessary for Rest
Remove those 3 and it works as needed. I set your top height to model top. You could just draw a 1.5" circle and use 2d adaptive or pocket if that's all you wanted to cut.
Please click "Accept Solution" if what I wrote solved your issue!
