3D Adaptive and tool boundary issue
I try to create the tool path to rough the cylindrical part after turning. The goal is to create the eye for cylinder.
I am limited to 4th axis positioning using standard version of Fusion. Tool limitation allows me to go only half depth for each side.
I try to create boundary but nothing works for me. I modelled the turning model and final part. In some occasions the software does not read the cylindrical feature. Or with other geometry does not to go half depth.
Is anyone who can look and give some advice.
Thanks Marcin
Steinwerks
I'm having a little trouble parsing what you want as I am not sure what you mean by "eye" but is this what you're looking for?
I changed your toolpath to .01mm tolerance (this makes a nicer toolpath and increases the resolution of the stock STL), disabled the manual Model addition ( leaving unchecked the box labeled Machine Cavities will keep the toolpath out of the hole), and turned on Rest Machining from Setup Stock.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
The Eye is the part 🙂
Thank you for help, it works now :).
Marcin
