Fusion Manufacture
3+1 Axis Okuma Milling- Post Processor B Axis Problem
2 REPLIES 2
Production42WVP
199 Views, 2 Replies
I'm programming a square part that is identical at 0 and 180, and 90 and 270. To program this in fusion I used circular patterns for the identical sides, and two WCS at 0 and 90. When I run the simulation it looks correct, but when I check the post, there is only B positions at 0 and 180.
Can I solve this within fusion or do I need to modify the post? Machine is Okuma MB-8000H and using Okuma post processor. All of the settings for the machine are default from the Fusion 360 library.
Thanks!
2 REPLIES 2
Solved my own problem.
Had to keep the work offset the same and change the tool orientation for the sides. Now I need to figure out why the post is outputting -90° instead of 270°..
If the part is truly identical, you could also just program up one side completely and then put it into a Pattern > Rotation to automatically duplicate it across a centerline
Seth Madore
