2d Trace, with angled tool does not follow selected geometry or model surfaces
I have a part that requires a 2mm radius fillet cleanup at the base of angled tubes that protrude from a plate. To gain access for the fillet, I angled the entry of the ball nose end-mill (with the 4th axis) to get under a lip on the tube (Refer attached files of selected geometry and video of machine path simulation).
My problem is... the tool path does not follow the geometry, it ramps down from entry and ramps back up towards exit, not following either the selected geometry or the model surfaces.
I have found that if I reduce the angle of the tool, it reduces the ramp deviation from the selected geometry and if I align the tool with the axis of the tubes the deviation does not occur.
I do not understand why this is happening, can anyone advise?
I can forward the file if necessary.
