Fusion Manufacture
2D Pocket: Toolpath previously generated, won't anymore
8 REPLIES 8
Message 1 of 9
FrodoLoggins
210 Views, 8 Replies
Generated just fine yesterday.
Screenshot 2023-05-02 at 10.23.31 AM.pngScreenshot 2023-05-02 at 10.23.46 AM.png
Setting ramp type to something other than "plunge outside of stock" allows toolpath to generate.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: FrodoLoggins
It doesn't like to see anything greater than .225" stepover 🤔
Seth Madore
Message 3 of 9
drd_808
somehow your bottom height got messed up. change it to model top or use selection and pick the top face
Message 4 of 9
FrodoLoggins
in reply to: drd_808
Nah it was like that originally; I copied that from a previous operation where I made selections.
But changing the bottom height to model top/selection(s) doesn't get it to generate for me:
Message 5 of 9
FrodoLoggins
in reply to: seth.madore
Yesterday (after it generated) it wasn't generating so I changed the stepover from .235" to .24". Generated fine. But now today with a .24" it won't generate.
But can confirm, generates fine now with a .224" stepover.
Message 6 of 9
seth.madore
I've opened CAM-44960 to investigate this, thanks for bringing it to our attention!
Seth Madore
Message 7 of 9
drd_808
"it was like that originally; I copied that from a previous operation where I made selections"
So just to be clear you posted an issue that gave a collision error without fixing a glaring collision that you're aware of? And its a copy and pasted process that has previous selections that you know are now missing?
Message 8 of 9
seth.madore
Leaving it set to "Selected Contours" is perfectly acceptable in most applications
Seth Madore
Message 9 of 9
FrodoLoggins
No, I:
1: Copy/pasted a working 2D pocket operation that generated ok from a previous setup.
2: Removed the selections and selected the top face that I wanted to mill.
3: Didn't select "model top" as my bottom height in the new operation because I shouldn't have had to.
