Fusion Manufacture
2D Pocket No Passes To Link Problem
9 REPLIES 9
Message 1 of 10
ali_aksoy5
224 Views, 9 Replies
Hello, I am using a 6mm wide blade to open a 6mm wide channel. However, I get the "No Passes To Link" error. How can I solve this?
Thanks.
9 REPLIES 9
Message 2 of 10
MichaelD872
in reply to: ali_aksoy5
You could use a 2D contour instead to fix the problem and chose one of the bottom corners of the pocket.
Message 3 of 10
ali_aksoy5
Thank you very much. I did as you showed and my problem was solved.
Message 4 of 10
MichaelD872
Happy to help!
Message 5 of 10
ali_aksoy5
Hello again, how do I need to follow to open the 6mm settings in the same way as in the image? Open chain doesn't work here.
Message 6 of 10
ali_aksoy5
By the way, I can do this with 2D Contour if I choose a maximum 5.9mm tip for the 6mm channel. However, I want to process a 6mm wide channel with a 6mm bit.
Message 7 of 10
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 8 of 10
ali_aksoy5
in reply to: seth.madore
Hello, I am sharing the file that I have the problem with. Thanks in advance for your help.
Message 9 of 10
MichaelD872
I changed the tool to 6mm then changed your selection to line only ( se countour sellection).
I also changed tangential fragment extension distance to half of the tool diameter so that it stays inside your pockets.
Do not mind the warning, its just because its ramping with a line.
I hope this helps. 🙂
Message 10 of 10
ali_aksoy5
in reply to: MichaelD872
Thanks, my problem is solved.
