Fusion Manufacture
2D POCKET CHAIN PROBLEM
4 REPLIES 4
info
188 Views, 4 Replies
Good morning,
I should perform the pocket machining in red color.
I used to use the pocket machining in 2d and it didn't give any kind of problem, while now with the new chain solution I can't perform it anymore.
I would like to know if I am doing something wrong.
Kind regards
4 REPLIES 4
seth.madore
in reply to: info
Hmm, certainly looks like a problem to me. We can work around this a bit by carefully selecting multiple contour chains, avoiding those small chamfers on some of the edges
After that, turn on Stock Contours, and set it to Silhouette selection. Result:
Seth Madore
seth.madore
in reply to: info
I've opened CAM-43043 to investigate this issue
Seth Madore
info
in reply to: seth.madore
Hi @seth.madore ,
I tried on another piece that I need to run, as you see attached, same problem. To remedy this problem I use the 3d pocket roughing function.
I await futiro feedback.
Regards
seth.madore
in reply to: info
Right, but doesn't Pocket and regular Pocket selections produce a valid toolpath on this piece?
Seth Madore
