Fusion Manufacture
2D Engrave missing parameter; HSMWorks offers it in Solidworks but not Fusion 360
1 REPLY 1
tsmith7GQU2
100 Views, 1 Reply
Not sure if this is where this should be in the forum. But it is a requested feature.
In Solidworks on the 2D Engrave options there is another parameter you can edit under the "passes" tab called "Contour Offset". This is missing inside of Fusion.
It is a slight issue because we have bunch of sketches made for engraving that are not "perfect" but the missing parameter makes them usable.
Labels (1)
1 REPLY 1
seth.madore
in reply to: tsmith7GQU2
And what does this parameter do (I've never used HSM)?
Do you have a sample Fusion file that would show the limitation of what you're trying to do?
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
