- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I have a Outside profile that I contoured with a 1/4 inch EM, There's a .04 radii on the profile that needs to be rest machined.
Chose the 1/16 EM to rest machine, Problem is when I try to give multiple roughing passes at .025 and a finishing pass of .0015 with a depth of cut of .025. Finishing on each depth.
For some reason it is only giving me finishing passes and its appropriate stepover. It's failing hard, I can't seem to get a roughing pass of .025 with a finishing pass of .0015.
For this instance, it's ok since it's ABS plastic, but if it were aluminum I would not be a happy fusion 360 customer.
Any thoughts on how to resolve this issue would be much appreciated.
Also, I am coming in with a 1/32 EM to finish it up, for some reason that tool seems to deal with the roughing passes and finishing pass just fine. Toolpath is good. Operation is duplicated as well.
