Fusion Manufacture
2D contour tab machining errors
7 REPLIES 7
Message 1 of 8
diana.petrova
201 Views, 7 Replies
Hei!
Since recent update I've encountered problem with placing tabs in 2D contour operations. Placement is correct, but toolpath is wrong. Here are some examples:
Toolpath should look like this:
And this is how some tabs are generated in Fusion now:
Problem could be solved by placing the tab in a bit different location, but would be nice to have different solution.
Once triangular tabs were defined in operation, but did not appear in final toolpath, while rectanguar tabs did:
7 REPLIES 7
Message 2 of 8
seth.madore
in reply to: diana.petrova
Can you share that file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 8
diana.petrova
in reply to: seth.madore
@seth.madore Any option to share the files privately?
Message 4 of 8
seth.madore
Of course!
Right click on the file in the Data Panel and select "Share Link". Copy that link and email me:
seth dot madore at autodesk dot com
Seth Madore
Message 5 of 8
diana.petrova
@seth.madoreJust sent the files
Message 6 of 8
seth.madore
The link to the files, not the files themselves, right?
Seth Madore
Message 7 of 8
diana.petrova
@seth.madore  Yes
Message 8 of 8
seth.madore
Yep, certainly broken..
For the TabProblem2, I suggest moving the tab over a bit so the edge is beyond the radius:
For TabProblem1, I've not yet found a suitable workaround..
Tickets are open for both of these issues:
CAM-42538 and CAM-42587
Seth Madore
