Fusion Manufacture
2D Contour Start & End Extensions not using default setting
4 REPLIES 4
Jon_Bancroft
231 Views, 4 Replies
In the new 2D Contour, contours selection window, the new default setting for extension distance was 0". I updated my user default setting to 0.1". However when I create new tool paths the new user default does not populate the field, it remains at 0".
I have reset the user default multiple times and rebooted Fusion and my PC with no change.
When I click the three dots and choose to "reset to user default" it correctly puts 0.1". It just doesn't actually do it from the beginning as it is supposed to. I believe this is a bug.
Hopefully this  is a quick fix (or I am using it wrong...), because currently I have to go into every single contour I select and change the extension distance every time.
4 REPLIES 4
Hi @Jon_Bancroft is what you are seeing similar to this video/workflow I made?
First I make a chain using single click (my default of 10 mm isn't respected/used).
Then when I create a chain using the little menu bar it uses my default of 10 mm.
Let me know if that matches what you are seeing.
Rasmus Pedersen
Senior Software Engineer
That is correct. I would expect it to show the extensions when I click directly on the contour but as shown in your video it does not.
Sorry this doesnt work @Jon_Bancroft as expected. I have raised CAM-42774 for this.
Thanks for making us aware of this.
Rasmus Pedersen
dgoller2RNYJ
in reply to: Jon_Bancroft
Seems as of today my saved defaults load...after I click the Edit icon for the contour.
Now if this loaded without me having to open/close the Edit dialog, it would be fixed.
