06:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Broad title, sorry.
I've encountered a problem and I'm not sure how to fix it.
The part I've programmed for is elliptical, and needs a nice finish on the outside before polishing.
When I create a 2D contour, with or without smoothing I get code with g1's and g2's. When run in the machine creates these flat sections that are about 1/16 apart. Same settings in MCAM with line/arc filter, code gets created with only g1 and small movements as you can see by the second post, which when ran in the machine was quite smooth.
Is there a way to get my post to look like MCAM?
(5/8" ENDMILL - FINISH) N12 S650 M3 N14 G54 N16 G187 P3 N18 G0 X-2.0288 Y-0.125 N20 G43 Z1. H2 N22 M8 N24 G0 Z0.1 N26 G1 Z0.0394 F120. N28 Z-3.175 N30 G41 X-1.9038 Y-0.1563 D2 F6. N32 G3 X-1.7475 Y0. I0. J0.1563 N34 G1 Y0.0024 N36 Y0.0048 N38 X-1.7474 Y0.0073 N40 X-1.7459 Y0.0731 N42 G2 X-1.7452 Y0.0876 I0.3124 J-0.0073 N44 G1 X-1.7406 Y0.1533 N46 G2 X-1.7393 Y0.1677 I0.3117 J-0.0218 N48 G1 X-1.7316 Y0.2331 N50 G2 X-1.7296 Y0.2475 I0.3104 J-0.0363 N52 G1 X-1.7189 Y0.3124 ...
N100 G00 G40 G49 G80 G90 N110 T2 M06 (5/8 FLAT ENDMILL) N120 G00 G54 X-2.2484 Y-.2478 S650 M03 N130 G43 H2 Z1. N140 M08 N150 Z.1 N160 G01 Z-3.17 F120. N170 G41 D2 X-1.9984 Y-.2487 F6. N180 G03 X-1.7475 Y.0004 I.0009 J.25 N190 G01 Y.0124 N200 X-1.7473 Y.0247 N210 X-1.7471 Y.0371 N220 X-1.7468 Y.0494 N230 X-1.7464 Y.0617 N240 X-1.7459 Y.0741
