Fusion Manufacture
2D Contour skipping sections
8 REPLIES 8
Message 1 of 9
FrodoLoggins
320 Views, 8 Replies
Selections:
Expected toolpath:
Result:
End mill diameter: .125"
Distance between parts: .135"
Stock to leave: .005"
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: FrodoLoggins
Well ya, it would.
You have .005" stock to leave, so the contours overlap. At which point, the offending moves are discarded. I actually would expect to see all internal moves removed (and they do if I set Stock to Leave to .0051")
 Setting it to .0049:
Seth Madore
Message 3 of 9
FrodoLoggins
in reply to: seth.madore
Oh that's unfortunate. Figured if the tool isn't going to hit anything and has .005" of clearance it would just mill what I told it to.
Perhaps some investigation on why they didn't all get trimmed?
Message 4 of 9
seth.madore
Floating point and rounding will be the answer, would stake a fair bit of $ on it
Seth Madore
Message 5 of 9
rhdfmail
I encountered this on a old program. a program that I have successfylly posted (and producing parts with)
Now I opended it up again and noticed that 2 operations in 2 different setups (multiple different parts that look almost the same) had an error.
Both of them where a 0,8mm endmill in a 0,9mm slot. Similar (as in exact the same) operations with a 0,5mm endmill in a 0,6mm slot still works
with some fiddeling i managed to get 1/3 of the slots to produce a toolpath. (of 66)
its a bit frustrating that operation  that you manage to get working all of a sudden decides to not work and you have no clue why
Message 6 of 9
seth.madore
in reply to: rhdfmail
@rhdfmail could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply
Seth Madore
Message 7 of 9
rhdfmail
cant share the original but I made a new project with just the problematic features and corresponding operations.
This is how I ran them last time, and no errors
Message 8 of 9
seth.madore
I've opened up CAM-44709 to investigate this issue.
As a workaround, you could program the one contour that is working and then put it into a Pattern > Rotation
Seth Madore
Message 9 of 9
rhdfmail
Good tip with the "workaround"
