- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any way to select a contourn to cut the profile of the attached part with out creating additional geometry?
I tried to do a screencast but couldn't get the utility to open. I've attached your file back with the contour selected. Click on one of the edges and then reclick on the chain to edit it. If you choose the closed chain box while in that mode and start clicking edges you can change the loop you are choosing. Again sorry I couldn't get a more visual help up, maybe someone else is working on one now.
Thanks, I thought that is what I was doing but I obvioulsly was not. It worked fine this time.
