2D contour problem
kamil.malec94
2D contour problem
kamil.malec94
Please see attached f3d file.
I cannot seem to generate a toolpath that would mill constantly in -Z. My path makes 0.040 step and then does a finishing pass at the same level. I would like it to run in constant -Z (helix milling). It usually works on circular parts with the "BORE" milling operation, but it does not work here bacause it is  a slot - this is why I used "2D CONTOUR".
I would appreciate your help!!
K
LibertyMachine
Turn off Multiple Depths on the Passes tab. You have Ramp turned on as well as Multiple Depths.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
kamil.malec94
Thanks for the help!
