It seems that there is an issue with tab generation happening currently. When I select a 2D contour and create tabs, it will display the tabs as usual, but when the toolpath is generated, most of the tabs seem to be ignored and removed.
Solved by seth.madore. Go to Solution.
This is a known issue with tabs on circular elements and we're working on a fix for this
We have fixed it internally and will be releasing it in a future update. Corporate policy prevents me from giving you a hard date, but I can tell you that fixing regressions such as this is a priority for us. I'll update this thread when the fix goes out!
The Tabs issue (on circular elements) has been fixed in the update that went out last night, terribly sorry for the inconvenience!
