2D Contour not machinhg full chain
forrest86LD6
forrest86LD6
Hi- I have attached a movie. The 2D Contour is not machining the complete chain that I selected. Why?
Thanks a lot,
Forrest
seth.madore
When creating a chain on a partial area, don't make multiple selections. Rather, press the ALT key on your keyboard, select the first entity to machine. Select that entity again and then build onto the chain. Press the "+" symbol when done.
Seth Madore
forrest86LD6
Hi Seth,
I tried that and it did not work. I have attached the file. Weird.
seth.madore
Turn Rest machining off. That tells 2d Contour to calculate the toolpath as if you have already machined the area with a larger tool.
Seth Madore
forrest86LD6
Perfect!
