Fusion Manufacture
2D Contour mills through tabs with both ways ramping
2 REPLIES 2
programming2C78B
105 Views, 2 Replies
only with ramp enabled does this happen. It respects the tab on one cut, then plows through it on the way back.
When I view Toolpath it also says it's using a plunge of 0 for the downhill section of the tab, but is set to 50in in the toolpath.
Please click "Accept Solution" if what I wrote solved your issue!
2 REPLIES 2
@programming2C78B
Yes, this has been known about for some considerable time, from memory the "workaround" was to use the Rectangular Tabs Instead of the Triangular.
Think it was pretty low on the priority list, Seth will probably have more info on where it is at 🙂 🙂 🙂
Unfortunately, this is a known bug (captured in CAM-23121) and there's been no recent work done on solving this issue.
Seth Madore
