Fusion Manufacture
2d contour hard to use
3 REPLIES 3
conjured2018
133 Views, 3 Replies
the 2d contour with the little box that opens is difficult to use. I find edits are brutal. I try to delete paths and still find in force. Using alt does not select what is needed all the time flashing back to full selection while trying to use it.
I do contours and then try to trim paths and fail. any suggestions?
3 REPLIES 3
seth.madore
in reply to: conjured2018
Hmm, I can't say that I've encountered what you're running into. If you have access to such software, could you make a screen recording that captures your frustrations? OBS Studio is a free and easy to use option
Seth Madore
conjured2018
in reply to: seth.madore
dont have driver for video app u linked to. thanks.JR
seth.madore
Screenshots, descriptions, part file?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
