Fusion Manufacture
2D Contour: Copy/Paste sometimes pasting the wrong thing
4 REPLIES 4
FrodoLoggins
165 Views, 4 Replies
Ok so if I copy a value from the End Extension Lead field, I'm able to paste that value as much as I want no problem:
However, if I copy a value from the Start Extension Lead field, I'm only able to paste it prior to hitting OK on the chain dialogue box. Once I hit OK, the word Chain gets pasted instead of the value I copied:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
4 REPLIES 4
seth.madore
in reply to: FrodoLoggins
Is this the only dialog where you've seen this happen?
Seth Madore
FrodoLoggins
in reply to: seth.madore
Only noticed this behavior after copying something from a text field within the Chain dialogue box. Copying from other fields (such as IPT field) pastes fine everywhere else including to text fields inside the Chain dialogue box.
Just tried the same thing with some other toolpaths.
Copy/Paste behavior is incorrect with Trace, Face, 2D Pocket toolpaths.
Copy/Paste behavior is completely fine with 2D Adaptive, Slot.
seth.madore
In the ones that you mention are incorrect, is that also in the Geometry Features dialog, or is it another text field?
Seth Madore
FrodoLoggins
Sorry that was a bit confusing.
I can copy a value from a field in the passes tab and when pasting that value into a geometry features dialogue field and it sometimes pastes correctly and sometimes doesn't:
