Fusion Manufacture
2D Circular has Multiple Depths - 0.04" as default
5 REPLIES 5
programming2C78B
90 Views, 5 Replies
I doubt this is intentional as no other path has it. Just FYI
my bandaid fix is edit the expression to be
tool_fluteLength * 0.9 and save that as a default, since we can't modify checkboxes.
Please click "Accept Solution" if what I wrote solved your issue!
5 REPLIES 5
You can change the default value to whatever you prefer in the dialog, and you can change the default on/off state of Multiple Depths by going into Compare and Edit.
Seth Madore
Cool, good to know. Does this apply to all paths enabling a default checkbox?
Should this still be fixed though?
Yes, the Compare and Edit workflow is well suited for all radio boxes or text fields that don't present a UI method of changing default behavior.
As for the stepdown amount, I'm not sure a change is needed, since that value is easily changed as well as the default value.
Seth Madore
Its just odd to me that it's the only toolpath with a Depth enabled.
Oh, I thought you were referring to the value of the stepdown, not the Multiple Depths being on/off. Yeah, that should get changed, I'll open a ticket.
-EDIT-
CAM-48636 has been opened to investigate changing the default off/on status
Seth Madore
