Fusion Manufacture
2D Adaptive: Tool full slots + plunges into stock
3 REPLIES 3
FrodoLoggins
137 Views, 3 Replies
It starts out taking a .05" stepover as specified but it ends up full slotting here:
I feel like it calculates the topmost stepovers after the bottommost (as expected) but decides to mill the top first.
Also plunges into stock at some points:
Screenshot 2023-11-16 at 3.53.49 PM.pngScreenshot 2023-11-16 at 3.54.14 PM.pngScreenshot 2023-11-16 at 3.54.19 PM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
jscott6SWZG
in reply to: FrodoLoggins
Try enabling slot clearing.  Also make your stock selection bigger so it starts machine before machining before it gets to the real stock
Also 2d adaptive needs enough room to work.  For example a 12.7 mm tool will not work in a 15mm slot without alter the inputs.
FrodoLoggins
in reply to: jscott6SWZG
Thanks but none of that stopped the tool from full slotting.
you need to select the bottom "full" profile of your part as stock. It thinks your upper level is only where it's highlighted blue.
why not try 3D adaptive?
Please click "Accept Solution" if what I wrote solved your issue!
