2d adaptive slotting starting outside of part
sendithard
sendithard
Semi-new to cam still. I was going over nyc cnc slotting tutorial where he tries to run an adaptive as a slotting strategy. They way I modeled the part and set the stock the endmill helix into the part. I couldn't get it to start outside the part and then I figured it out. I confined it not to with the geometry selection.  In my second part I sketched out a little area for the part to start outside and it worked nicely. Is this a reasonable idea or strategy and are sketches used often  or rarely in cam toolpaths?
jedQB94J
Why do you want to slotting around the part?
Jacob
sendithard
I just do a random tutorial each day. https://www.youtube.com/watch?v=4SusSMezMUw
I think my solution is fine, but I was curious if that is true and if sketches are used frequently with cam programing paths. You don't see a ton of tutorials using sketches.
JaumeMartinez
Hi @sendithard ,
Sometimes I use that trick when determining the machining boundary in adaptive roughing operations when I need to avoid and specific face or region of the part.
Here you can see an example:
Solved: Re: How do I avoid this face in 3D addaptive clearing? - Autodesk Community - Fusion 360
Kind regards.
Jaume M. Consultor CAD-CAM-CNC
Autodesk Gallery
autodesk-expert-elite-member-forum-signature-313x46
firmaforo
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta | Please give me Kudos and mark this response as Accept as Solution if it answers your question
