Fusion Manufacture
2D Adaptive Simulation And Component Out Of Date Errors
5 REPLIES 5
mitchdryden
119 Views, 5 Replies
Hi Folks,
I have a couple of things going on it seems, I haven't used Fusion360(I'm on the hobby version) for months as I've been refurbing an older Multicam CNC.
On my previous CNC I cut the nut blocks(have attached the file), today I went to cut more of them on the refurbed CNC as I will need them to hold down a bigger waste board.
Issue 1:
When I opened Fusion, I added a new machine profile(just a generic 3 axis one, and changed the name to Multicam), I opened the nut block file I got the 'Component Out Of Date Error', followed the prompts to return to the 'Design' space, but there is no error message there or any choice of 'Get Latest' anywhere. So started googling, tried everything that was suggested from forum posts and Autodesk.
Got over that, so just drew up new one, it's a quick and easy shape.
Issue 2:
Within CAM(used the same settings as when I have cut them previously) , first cut is a 2D adaptive, in the simulation, as soon as the bit hits the stock it turns red and stops....I can not for the life of me work out why, have played around with top height and lead in/out settings, but nothing seems to work....ggrrr...so frustrating.
What am I missing? Any help advice appreciated
FYI: Fusion Version #2.0.17721 x 86_64
       Windows 10 Home 64 bit
5 REPLIES 5
seth.madore
in reply to: mitchdryden
I can't help you much with the Out of Date reference, as it would require a file that's still in that state (which it's no longer at).
However, the reason you're having a red mark (collision) is that you've defined your material in such a size that is allowing the 2D adaptive toolpath to rapid into the part. You can either define smaller stock, or turn on Stock Contours to position the tool outside of the stock:
If you're okay with a full rapid plunge into material (sometimes okay with wood), you can just turn off the "stop on collision" setting in the Simulation. 
Seth Madore
mitchdryden
This file should still have the 'Out Of Date' message, if you could look that would be great. Thanks, that fixed the collision, staring me in the face
seth.madore
Negative, all bodies are local components, not Derive or XREF. Thus, no OOD warning is present 😞
Seth Madore
mitchdryden
Thanks for looking Seth, don't really understand what you just said, hopefully doesn't affect any other files too
seth.madore
In order to have an Out of Date (OOD) warning, one must first have components that were inserted from another file/project, either thru an "XREF" (external reference) or by use of the Derive function. The file you shared had neither present in the history, as they were bodies that were created in that file.
Seth Madore
