Fusion Manufacture
2D adaptive leaving material and not machining past open corners
8 REPLIES 8
Message 1 of 9
t.g.mandel
252 Views, 8 Replies
I would like to know what settings I need to change so that no material is left in the open corners. Thank you.
See image below:
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: t.g.mandel
It'd be easier to demonstrate if you could share your file 🙂
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 9
engineguy
@t.g.mandel
Without a sample Fusion file as @seth.madore suggests this is just a guess of how it might be done, the shape is not a million miles away from your image, have you tried using the "Pocket" option in the 2D Adaptive selection as a possible method? See images below and attached Fusion file.2D Adaptive Pocket example.jpg
Message 4 of 9
t.g.mandel
in reply to: seth.madore
Thank you for the response and offer to help.
I have attached the requested file.
Note that I tried, with a new rectangular sketch, to add a new wider boundary. However my inexperience  leads only to failed attempts to use it to solve the issue.
Thank you for taking the time to look at it.
Message 5 of 9
t.g.mandel
in reply to: engineguy
Thank you for your help - I appreciate it. When I had tried that option earlier I got an error:  "unsupported geometry for open 2D pocket"
Message 6 of 9
t.g.mandel
I tried more combinations and think I may have solved it.
I chose chains and then open chain>tangent>distance extension> 10 mm. If you have time please let me know if this is a reasonable method, or if there is a better one for this particular machining. See images below:
Message 7 of 9
t.g.mandel
I kept at it and posted images of what I think is a workable method.
Thank you again.
Message 8 of 9
engineguy
@t.g.mandel
The issue is with your Model, it is "broken", you need to go back to the Design Mode and fix the model and it should work, have a look under the Model as shown in the image below.
Message 9 of 9
t.g.mandel
I had not even noticed that - thank you. I went back to the sketch and saw the problem areas and how they occurred, so I can use this knowledge and avoid this in future work so that is a bonus. I modified the sketch/model to eliminate these two anomalies.
