Whenever I try to use a 2D Adaptive toolpath, even to simply rough the end of a part, it fails to generate a toolpath.
The error it gives is Error: Failed to evaluate expression for parameter Calculation Tolerance and Error: Failed to write Job File.
I've tried changing the cutting and smoothing tolerances to various values, using fixed values for all of the settings in the 2D adaptive dialogue box instead of my usual expressions (such as tool_diameter * 0.05), even settings that I'm not using, switching to a different tool. I've tried to do other pockets on the part with the same result.
I use 2D Adaptives all the time to do what I'm trying to do. It seems as though an update broke something. There are no values in the options of the adaptive dialogue box that are red indicating an invalid number and I have changed nothing since the last time I programmed a part with an adaptive successfully a few weeks ago. Any ideas?
