2D Adaptive clearing doesn't recognize stock or selcted chain
carlgren.martin
carlgren.martin
Hi, can someone advise what I'm doing wrong? I have selected an open chain (left half of the part) to machine with 2D adaptive clearing. First, the operation doesn'r recognize the stock from this setup (Setup2), nor does it only machine the slected open chain, it creates tool paths around the complete part. What am I doing wrong?
Thanks and regards,
Martin
Replies (9)
carlgren.martin
Here is also a picture of my "Open chain selection".
seth.madore
2D Adaptive is not model aware, so it's limited by your selections.
Looking at your file, I'm not certain what it is you're trying to machine. All the material at the depth you've defined is already removed, isn't it?
Seth Madore
programming2C78B
everything in that blue window will be machined....use 3D adaptive for this job.
add a constraint if you only want to do 1/2 per operation.
Please click "Accept Solution" if what I wrote solved your issue!
You can see my stock in the picture "Stock.jpg", you can se my chain selection in the picture above. The stock is watercut and follows the profile of the part, as I have defined in my "Setup2". But Fusion creates tool paths all around the part, not only the left side of the part where I have made my chain selection. It also created toolpaths for a huge "Block stock", not related to my stock I have defined in the Setup.
In the picture below I have manipulated the toolpaths using a 2D Contour, this is something what I would like the 2D adaptive to create.
It's the 2D Adaptive in Setup2 I'm struggling with.
seth.madore
2025-03-06_11h33_58.mp4
Video Player is loading.
Current Time 0:00
Duration 2:12
Loaded: 7.45%
Stream Type LIVE
Remaining Time 2:12
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Seth Madore
    Thanks! This worked much better after some tweaking with boundary constraints etc. Thanks again, much appreciated! Greetings from Sweden.
    Thanks! But so even if I only choose open contour that is half of my part, I need to make a "custom stock" that is also only the same half of the part? I would think, or hope that Fusion would recognize the stock in the setup and still only machine from where the selection "open contour" area was.
    But thanks! Always good to learn new ways. 🙂
    seth.madore
    2D Pocket and 2D Adaptive will always project out to the bounding box of the defined stock. To prevent that, you need to define a stock profile to limit to just the areas you want.
    If you're looking for some intelligence, it's not to be found in the 2D toolpath. 3D Adaptive is much better in this regard.
    Seth Madore
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
