Fusion Manufacture
2 D Contour cutting smaller than model
2 REPLIES 2
conjured2018
58 Views, 2 Replies
Please see attached file. the first operation in the manufacture tab is a 2d contour for a  box back. the contour cut is inside the box boundary, and is the actual cut, approx. .25 short. the operation is not cutting the actual dimensions.
I have not seen this before yet can not fix. Please help. Thank u, JR
2 REPLIES 2
This happened because you selected a sketch contour, and fusion doesn't know what side is which. Select the actual edge of the MODEL, and it'll understand where the "outside" is.
you simply selected the wrong side of the contour. Select it, edit it, select reverse. You can also click on the actual red arrow as well to flip sides.
Please click "Accept Solution" if what I wrote solved your issue!
thank you JR
