Z axis try to do full cut G28 G91 Z0
kris.chlapek
kris.chlapek
Hi Guys
Newbie here and I`m going to run the attached code but when I`m adding this to a simulator, it looks like it wont to do the full depth cut on Z axis as it`s looks like the XYZ zero which i`m setting on the vice edge is the start on this Gcode.
Any advice please?
G28 is a move on machine coordinates. That is a move to Z zero in machine coordinates which is usually the highest that the Z axis can raise.
kris.chlapek
Hiya.
That's correct. However the simulator makes me think that the G28 is called and then the tool goes to hit the zero on the vice. Anyway, I think I need to try to run it with the estop in my hand🤔
