Wrapping Text for CNC Milling - Single line font
jeph00
jeph00
Good day.
I want to wrap this text around the outside of this cylinder. Emboss does not work with single line font so I would like to know if there is another way to do this.
Thanks.
a.laasW8M6T
Hi
So what you need to do is explode the text(right click on the text and select explode text)
then create a new sketch, next select project to surface from the Create - Project/include menu
select the cylinder you want to project to and then the exploded text
If you want to engrave it, I have set an example in manufacture using trace, rather than selecting each individual line you can select the sketch.
Regards
Andrew
