Work offset problem
Work offset problem
adventuremetal
Work offset problem
adventuremetal
Just posted the attached file and went to run it...for some reason the the tools are all starting appoximately 1.30 in  x+.
Luckily I was hoving over feed hold when the face mill did a  z- rapid in the middle of the part.  I double checked my offset on the machine it's good so I'm feeling stumped.  I also posted a picture to show where the face mill thought was the end of the facing pass Any ideas?
Roger
engineguy
@adventuremetal
Looks to me like a Setup issue, the X and Y axis seem to have been transposed somehow, have a look at your G Code and check the actual numbers, first image is your original setup, the second one is with the setup swapped.
Might this be the problem ??????
