Why is rest machine not working in 3D pocket toolpath on 2nd setup?
aokere
aokere
I've attached the file here. Thank you in advance!
a.laasW8M6T
Hi
First reason is that in your second setup you need to turn on "Continue Rest Machining" in the stock Tab
Second, in your pocket operation you need to set the rest machining Source to "From previous operations"
Now the pocket toolpath will correctly do rest machining
Andrew Laas
Senior Machinist, Scott Automation
aokere
Perfect thank you very much!
