Hello all,
I'm quite new with Fusion 360 and I've a problem that I can't resolve despite having fiddled with several settings: My tool, when generating the path, doesn't go on my model edges, leading in my final milled model being almost 5mm too short on X and Y.
Here is my model, front view of the edge:
And here is where the tool is milling, missing the edges:
My form is a hole in a piece of wood (cabinet door) that I'm trying to recreate and as you can see, the final result is too short as expected, some milling is missing (only check on the Y, the X is smaller on purpose):
What can I do for the tool to really take all the piece into account when generating the toolpath?
I'm milling with a 3.2mm bit with 0.1mm height steps.
My model is 4cm height but my final milled piece is only 3.5cm height.
Thank you all for your help!
