@cekuhnen wrote:
@LibertyMachine
Well that is actually our mystery right now. Different tools can have different sizes so we need to accommodate for that.
the Fusion interface gives you few start points but they are all well on the initial stock like in the screenshot below
I am not sure how one could or should use those points on the ground plane or inside the stock volume ?!
is there a way on the build platform next to it to find rest position like 2 cm away from the stock and then
after a tool chance use the build platform to find the correct z position?
During the initial setup stages, you can establish any point you would like as your origin point. Top, bottom, left, right, anything basically. Thing is, you sort of need to keep that location.
Now, it is technically possible to switch origin points halfway through a job, but the likelihood of tools blending well to previous cutting operations are very slim, without a decent amount of trial and error.
The above statement concerns mostly the X and Y repeatability of switching origin points along the X and Y axis.
Now, what you "could" do is shift the Z origin down to the bottom plane. However, if you touched off on raw stock that was oversize from what you planned, you would be off that amount when you started to cut on your new tool.
Lastly, yes, you could use the "build platform" next to the part to establish tool heights. What I would do:
Take the tool that is still in the spindle (assuming the first tool is still in?) Bring it down to near that height, using a small block of a known height (gage block, bar stock, etc). Bring the tool down until the block barely fits under the tool (careful not to damage the tool). Now, compare the Z value to that of it's initial touchoff. The difference would be the Z shift value and it would become a positive value that is placed into G54 Z offset (WARNING: I'm assuming your control actually is working like a convention CNC control, your results may vary)
Now you should be able to touch off all your tools on that build platform
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
