Vertical Lead In/Out
stuart
stuart
Hi all
Can anyone explain the benefit of using Vertical Lead In and out under Linking?  Im having a problem with it being a default on most of my toolpaths and my older HAAS wont allow it so would prefer to turn it off if anyone knows how.  I cant really see its use?
Cheers
Steinwerks
The general idea is to keep the machine moving at all times so axes never come to a complete stop. Instead of point moves the motors transition allowing the machine to potentially avoid axis acceleration issues, which in turn can speed up run times.
How won't your older Haas allow for vertical leads? If they aren't in a G18 or G19 plane they are linearized and left on G17.
I do agree it increases code though and makes it more difficult to make simple edits at the machine as necessary.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
stuart
Hi Thanks for the rapid reply. That makes sense. For some reason the
Generic Post isnt outputting the G18 and G19. Maybe I have have lost
something in my Post when I have tweaked it. Ill test a fresh post. Ho
can I change Fusion to default to zero? I think the easy code changing on
the machine as you mentioned may be a problem for the guys on the machine.
Best Regards
Stuart
Steinwerks
Is it linearizing the arcs? If so, you'll get something that looks like this:
X0.3033 Y0.1035 Z-0.3809
X0.2955 Y0.1034 Z-0.38
X0.2878 Y0.1033 Z-0.3785
X0.2803 Y0.1032 Z-0.3764
X0.2729 Y0.1031 Z-0.3736
X0.2658 Y0.103 Z-0.3704
X0.2589 Z-0.3665
X0.2524 Y0.1029 Z-0.3622
X0.2462 Y0.1028 Z-0.3573
X0.2405 Z-0.352
X0.2352 Y0.1027 Z-0.3462
X0.2303 Y0.1026 Z-0.34
X0.2259 Z-0.3335
X0.2221 Y0.1025 Z-0.3266
X0.2188 Z-0.3195
X0.2161 Z-0.3122
X0.214 Z-0.3046
X0.2124 Y0.1024 Z-0.2969
X0.2115 Z-0.2891
X0.2112 Z-0.2813
If you want to set the defaults to no lead arcs, set it to zero, right-click on the value field, and click the "Set as Default" option on the pop-up menu. You can do this for any field, and some checkboxes will also be set as defaults if you choose "Set All as Default" (and that's one that you really want to be sure of so you're not fighting all the defaults you set accidentally at one point).
Neal Stein
Find me on:
