var productLink - Global Parameter? Trying to Make an Array of a Parameter
jonathanBUCVS
jonathanBUCVS
I am trying to output the variable productLink into my Excel setup sheet, but I am having trouble. It appears to be a global variable, because i cannot read it with getParameter("operation:tool_productLink"), but I can read it with getGlobalParameter("operation:tool_productLink").
My current thought for a work around is to make an array of all the productLink values, which would be indexed by Section, and I could call each one based on the section number. I already have a for loop counting number of sections.
I am getting stuck trying to make an array of all of the productLink variables from the record so I can reference them to the individual section and read them into the final tool list array. But if there is a better way, I am open to that too.
jonathanBUCVS
@boopathi.sivakumar  when you get a chance, could you help me with this productLink parameter?
In unrelated news, I was able to adapt your tool list header code to my Excel setup sheet post, so that too outputs "duplicate" tools with different offsets, so thank you again for that.
jonathanBUCVS
Found some help from a fellow user in a related thread here if anyone needs a solution: https://forums.autodesk.com/t5/hsm-post-processor-forum/csv-setup-sheet-how-to-output-quot-links-quo...
