Using Multi-Axis Contour to cut a rounded surface with square endmill
'm trying to use the tip of a 1/2" square endmill to cut this sloped surface. When using Multi-Axis Contour, it mostly works, but the tool is tilted slightly away from "normal to the surface." The tool path won't let me override the tilt angle because it only works for a rounded tool. Also, adjusting the lean and lead/lag angles just shift the tool to cut along one of the lead curves, but not the correct one. You can see in the picture how I can get really close to cutting the surface correctly, but its not quite right.
