Using high feed G1 instead of G0 no matter what I select.
aboutmetal
aboutmetal
This problem begun a few days ago.
We are using Haas Old Control post.
On the post processor window: No matter what we select  under the "(Built in) High feedrate mapping it keeps outputting "(Using high feed G1 F5000 instead of G0.)".
What do I need to do to make it not use this option...
Thank you,
Jorge
engineguy
@aboutmetal
Do you not have the "Use G0" option to select as in the image below, if you go for that then watch out for the "Dogleg" rapids 🙂 🙂
