My name is Alejandro Gonzalez
Thanks in advance for any advice you may help me with
I am fairly new creating tool paths for the CNC router
and to make it better I am trying to cut ACM (Aluminum Composite Material ) in which a 90 degrees V tool with .090 flat tip goes into the material leaving only like .015" above the bottom.
The problem that I am having is that no matter how I want the groove to be centered with the bending centerline of the flat pattern or with a line created in the Manufacture Model environment as a sketch the tool is moved to the left of the line.
I am using a 2D Contour strategy
On the Passes tab, I have tolerance = .0004
Sideways compensation: left
Compensation Type = off
Compensation radius allowance= .01965
and that's basically what I have
And the toolpath simulation shows the tool to a side of the line
never on top exactly
I am attaching a model in which you can see that I moved the line (open contour (and maybe that's the real problem here)) to make sure that the cut is on the center of a line that goes between vertices (imaginary line )
Please advise
