Using a fully-threaded screw in a partially-threaded hole
27_aiden_kim
27_aiden_kim
Is it standard practice to use a fully-threaded screw in a partially-threaded hole, like this?
I have a really long screw hole, but the threads are really only needed on the bottom side. If the hole is fully threaded, it's going to take a long time to screw it all in, especially since there are multiple such holes.
Online, I could only find examples of using partially-threaded screws for partially-threaded holes, but I was wondering if I could use fully-threaded screws in partially-threaded holes.
davebYYPCU
Technically we would not normally see that set up for a single hole.
Two plates, it’s most common to have a bottom part to hold a top plate in position.
Standards - are designed by doing what’s needed, suits the current use.  Yes you could make that a bottom plate, would not normally have the countersink on it.
Might help….
programming2C78B
I have no clue what Dave said
Yes, of course you use a fully threaded screw. The top clearence dia is larger than your bolt.
The engineers will call this "thread relief"
Please click "Accept Solution" if what I wrote solved your issue!
