unknown toolpath
unknown toolpath
dermot.young
Message 1 of 8
unknown toolpath
dermot.young
Hi, I wrote a program using Adaptive Clearing the below happened. Any help would be appreciated.
pict1pict1Cad MmodelCad Mmodel
Replies (7)
Message 2 of 8
seth.madore
Can you share the file?
What control and Post Processor are you using?
Seth Madore
Message 3 of 8
dermot.young
Using a fanuc post.
ProtoTrax RMX - XYZ CNC Mill
Message 4 of 8
DarthBane55
Not the NC file, but the Fusion file, so that someone can have a look at it in Fusion and see what's going on.
Message 5 of 8
seth.madore
While it's true that the actual Fusion file would be most helpful, we are able to glean some info from the NC code. Looking at your code through a backplotter, we see nothing of the sort in those areas where you have issues:
Do you have a Fanuc control on your machine? There IS a ProtoTrak post available, I think that covers their enclosed CNC versions. https://cam.autodesk.com/hsmposts?p=prototrak
Seth Madore
Message 6 of 8
dermot.young
thanks for your reply how do i install the new post?
Message 7 of 8
dermot.young
Thanks for coming back quickly
See below attached files,
Post Processor Fanuc / fanuc
Message 8 of 8
seth.madore
Here's an article on how to install local post processors. Once you know it's a good post that works for your machine, consider adding it to your cloud library
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Seth Madore
