Unit Conversion in Dimension Tool
powerflexplacement
powerflexplacement
My workplace has been moving from Solidworks over to Fusion360,
On Solidworks, when you are dimensioning a feature on a part, and have units set to mm, if you enter 3/4" it will dimension it to that, and automatically convert it to mm and display it in mm, so entering 3/4" or 3/4in will give an output of 19.05mm
Any ideas on how to do the same in Fusion360? I've tried the above but doesn't seem to work...
ltomuta
You have to use an expression like this: "(3/4)*1 in"
powerflexplacement
seems like a long way of doing it when other softwares are able to figure it out without having to enter an equation for it
ltomuta
Eventually it will get better in Fusion as well but currently that's where
things are.
HughesTooling
@powerflexplacement I replied in your other post but just for reference you can enter 3"/4.
Mark Hughes
Owner, Hughes Tooling
powerflexplacement
Thanks Mark,
Saves having to add the brackets in.
